Проблема с gettools-0.19
sda1
Сообщение sda1 »
configure: WARNING: unknown target-version 1.7, please update gt_JAVACOMP macro
configure: WARNING: libacl development library was not found or not usable.
configure: WARNING: gettext-tools will be built without ACL support.
ar: `u' modifier ignored since `D' is the default (see `U')
warning: [options] bootstrap class path not set in conjunction with -source 1.3
1 warning
libxml/tree.c: In function 'xmlNodeSetBase':
libxml/tree.c:4851:10: warning: passing argument 1 of 'xmlFree' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
  xmlFree(fixed);
libxml/tree.c:4851:10: note: expected 'void *' but argument is of type 'const xmlChar * {aka const unsigned char *}'
1 warning
1 warning
/usr/bin/install: не удалось выполнить stat для «ChangeLog.inst»: Нет такого файла или каталога
Вот такие ошибки не знаю что и делать :?
