Имеется CentOS 6.6
В качестве почтового сервера iRedMail 0.8.7
Сборка Postfix+MySQL+SpamAssassin+ClamAV+AmaViS+Dovecot+RoundCube
Почта не ходит в обе стороны.
Вот что пишет Postfix в логе :
Sep 27 20:57:26 example postfix/postfix-script[13315]: stopping the Postfix mail system
Sep 27 20:57:26 example postfix/master[12221]: terminating on signal 15
Sep 27 20:57:26 example postfix/postfix-script[13408]: starting the Postfix mail system
Sep 27 20:57:26 example postfix/master[13410]: daemon started -- version 2.11.0, configuration /etc/postfix
Sep 27 20:59:43 example postfix/smtpd[13423]: connect from mail-wi0-f180.google.com[209.85.212.180]
Sep 27 20:59:44 example postfix/smtpd[13423]: 426BB2801A7: client=mail-wi0-f180.google.com[209.85.212.180]
Sep 27 20:59:44 example postfix/cleanup[13430]: 426BB2801A7: message-id=<CA+vxW5w84momMOzZT+Zorj_OhOvj-cCE02X_ZzE6S_-0TaLg0Q@mail.gmail.com>
Sep 27 20:59:44 example postfix/qmgr[13412]: 426BB2801A7: from=<user@gmail.com>, size=1709, nrcpt=1 (queue active)
Sep 27 20:59:44 example postfix/smtp[13435]: fatal: open lock file pid/unix.smtp-amavis: file has 2 hard links
Sep 27 20:59:44 example postfix/smtpd[13423]: disconnect from mail-wi0-f180.google.com[209.85.212.180]
Sep 27 20:59:45 example postfix/master[13410]: warning: process /usr/libexec/postfix/smtp pid 13435 exit status 1
Sep 27 20:59:45 example postfix/master[13410]: warning: /usr/libexec/postfix/smtp: bad command startup -- throttling
Sep 27 21:00:45 example postfix/smtp[13445]: fatal: open lock file pid/unix.smtp-amavis: file has 2 hard links
Sep 27 21:00:46 example postfix/master[13410]: warning: process /usr/libexec/postfix/smtp pid 13445 exit status 1
Sep 27 21:00:46 example postfix/master[13410]: warning: /usr/libexec/postfix/smtp: bad command startup -- throttling
Sep 27 21:01:46 example postfix/smtp[13501]: fatal: open lock file pid/unix.smtp-amavis: file has 2 hard links
Sep 27 21:01:47 example postfix/master[13410]: warning: process /usr/libexec/postfix/smtp pid 13501 exit status 1
Sep 27 21:01:47 example postfix/master[13410]: warning: /usr/libexec/postfix/smtp: bad command startup -- throttling
Мои конфиги.
main.cf :
queue_directory = /var/spool/postfix
command_directory = /usr/sbin
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
mail_owner = postfix
unknown_local_recipient_reject_code = 550
debugger_command =
PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
ddd $daemon_directory/$process_name $process_id & sleep 5
sendmail_path = /usr/sbin/sendmail.postfix
newaliases_path = /usr/bin/newaliases.postfix
mailq_path = /usr/bin/mailq.postfix
setgid_group = postdrop
html_directory = no
manpage_directory = /usr/share/man
sample_directory = /usr/share/doc/postfix-2.11.0/samples
readme_directory = /usr/share/doc/postfix-2.11.0/README_FILES
#inet_protocols = ipv4
virtual_alias_domains =
myhostname = example.com
myorigin = example.com
allow_percent_hack = no
swap_bangpath = no
mydomain = example.com
mydestination = localhost
biff = no
inet_interfaces = all
mynetworks = 127.0.0.0/8
mynetworks_style = host
smtpd_data_restrictions = reject_unauth_pipelining
smtpd_reject_unlisted_recipient = yes
smtpd_reject_unlisted_sender = yes
smtp_tls_security_level = may
smtp_tls_CAfile = $smtpd_tls_CAfile
smtp_tls_loglevel = 0
smtp_tls_note_starttls_offer = yes
smtpd_sender_restrictions = permit_mynetworks, reject_sender_login_mismatch, permit_sasl_authenticated
delay_warning_time = 0h
maximal_queue_lifetime = 4h
bounce_queue_lifetime = 4h
recipient_delimiter = +
proxy_read_maps = $canonical_maps $lmtp_generic_maps $local_recipient_maps $mydestination $mynetworks $recipient_bcc_maps $recipient_canonical_maps $relay_domains $relay_recipient_maps $relocated_maps $sender_bcc_maps $sender_canonical_maps $smtp_generic_maps $smtpd_sender_login_maps $transport_maps $virtual_alias_domains $virtual_alias_maps $virtual_mailbox_domains $virtual_mailbox_maps $smtpd_sender_restrictions
smtp_data_init_timeout = 240s
smtp_data_xfer_timeout = 600s
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_non_fqdn_helo_hostname, reject_invalid_helo_hostname, check_helo_access pcre:/etc/postfix/helo_access.pcre
queue_run_delay = 300s
minimal_backoff_time = 300s
maximal_backoff_time = 4000s
enable_original_recipient = no
disable_vrfy_command = yes
home_mailbox = Maildir/
allow_min_user = no
alias_maps = hash:/etc/postfix/aliases
alias_database = hash:/etc/postfix/aliases
message_size_limit = 15728640
virtual_minimum_uid = 2000
virtual_uid_maps = static:2000
virtual_gid_maps = static:2000
virtual_mailbox_base = /var/vmail
transport_maps = proxy:mysql:/etc/postfix/mysql/transport_maps_user.cf, proxy:mysql:/etc/postfix/mysql/transport_maps_domain.cf
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql/virtual_mailbox_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql/virtual_mailbox_maps.cf
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql/virtual_alias_maps.cf, proxy:mysql:/etc/postfix/mysql/domain_alias_maps.cf, proxy:mysql:/etc/postfix/mysql/catchall_maps.cf, proxy:mysql:/etc/postfix/mysql/domain_alias_catchall_maps.cf
sender_bcc_maps = proxy:mysql:/etc/postfix/mysql/sender_bcc_maps_user.cf, proxy:mysql:/etc/postfix/mysql/sender_bcc_maps_domain.cf
recipient_bcc_maps = proxy:mysql:/etc/postfix/mysql/recipient_bcc_maps_user.cf, proxy:mysql:/etc/postfix/mysql/recipient_bcc_maps_domain.cf
relay_domains = $mydestination, proxy:mysql:/etc/postfix/mysql/relay_domains.cf
smtpd_sender_login_maps = proxy:mysql:/etc/postfix/mysql/sender_login_maps.cf
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
broken_sasl_auth_clients = yes
smtpd_sasl_security_options = noanonymous
smtpd_tls_auth_only = yes
smtpd_recipient_restrictions = reject_unknown_sender_domain, reject_unknown_recipient_domain, reject_non_fqdn_sender, reject_non_fqdn_recipient, reject_unlisted_recipient, permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
#smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_non_fqdn_helo_hostname, reject_invalid_helo_hostname, check_policy_service
#smtpd_end_of_data_restrictions = check_policy_service inet:127.0.0.1:10031
smtpd_tls_security_level = may
smtpd_tls_loglevel = 0
smtpd_tls_key_file = /etc/pki/tls/private/iRedMail.key
smtpd_tls_cert_file = /etc/pki/tls/certs/iRedMail_CA.pem
smtpd_tls_CAfile = /etc/pki/tls/certs/iRedMail_CA.pem
tls_random_source = dev:/dev/urandom
mailbox_command = /usr/libexec/dovecot/deliver
virtual_transport = dovecot
dovecot_destination_recipient_limit = 1
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/dovecot-auth
content_filter = smtp-amavis:[127.0.0.1]:10024
smtp-amavis_destination_recipient_limit = 1
master.cf :
smtp inet n - - - - smtpd
#smtp inet n - n - 1 postscreen
#smtpd pass - - n - - smtpd
#dnsblog unix - - n - 0 dnsblog
#tlsproxy unix - - n - 0 tlsproxy
#submission inet n - n - - smtpd
#628 inet n - n - - qmqpd
pickup unix n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
relay unix - - n - - smtp
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_mynetworks,permit_sasl_authenticated,reject
dovecot unix - n n - - pipe
flags=DRhu user=vmail:vmail argv=/usr/libexec/dovecot/deliver -f ${sender} -d ${user}@${domain} -m ${extension}
smtp-amavis unix - - - - 10 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
-o disable_dns_lookups=yes
-o max_use=20
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o mynetworks_style=host
-o mynetworks=127.0.0.0/8
-o local_recipient_maps=
-o relay_recipient_maps=
-o strict_rfc821_envelopes=yes
-o smtp_tls_security_level=none
-o smtpd_tls_security_level=none
-o smtpd_restriction_classes=
-o smtpd_delay_reject=no
-o smtpd_client_restrictions=permit_mynetworks,reject
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o smtpd_end_of_data_restrictions=
-o smtpd_error_sleep_time=0
-o smtpd_soft_error_limit=1001
-o smtpd_hard_error_limit=1000
-o smtpd_client_connection_count_limit=0
-o smtpd_client_connection_rate_limit=0
-o receive_override_options=no_header_body_checks,no_unknown_recipient_checks,no_address_mappings
Третий день воюю. Помогите.
не ходит почта
- Авторитетный участник
Re: не ходит почта
Включай дебаг, так не понято. И весь дебаг вываливай.
И доку сюда скинь, по которой настраивал
Вот ошибка
Вот ошибка
Sep 27 20:59:44 example postfix/smtp[13435]: fatal: open lock file pid/unix.smtp-amavis: file has 2 hard linksRe: не ходит почта
Нашёл все хардлинки на файл unix.smtp-amavis. У него вообще их не должно быть. Всё что нашёл - "permission denied". Изменить не даёт, хотя я под рутом.
Этот сервер проработал больше года без нареканий. Был сбой по питанию и он ,наверное ,наделал эти хардлинки.
Re: не ходит почта
Стёр этот файл - создал такой же. Заработало. Спасибо за помощь.
Re: не ходит почта
Просто читай внимательно логи
Re: не ходит почта
Спасибо.
Ошибку я увидел сразу. Просто с хардлинками запутался...
