Xombrero,веб-браузер.
~/.xombrero.conf
## GENERAL SETTINGS
# parse the contents of another configuration file
 include_config	= ~/.xombrero_alternate.conf
## GENERAL SETTINGS
# The strategy for the config file is as follows:
# Boolean values are the opposite of the default and need to simply be
# uncommented to alter the default.
# Text values *are* set to the default and in order to change them one must
# uncomment the option *and* change the value.
# NOTE: browser_mode and gui_mode MUST be the first entries in this
#file!
# Normal browser operation (default).
browser_mode		= normal
home			= https://google.com
download_dir		= ~/Загрузки
# download_mode		= start
# download_notifications = 1
# window_maximize	= 1
window_width		= 1330
window_height		= 735
# enable_spell_checking	= 1
spell_check_languages	= ru_RU
# default_zoom_level	= 1.0
encoding		= UTF-8
ssl_ca_file		= /usr/share/certs/ca-root-nss.crt
ssl_strict_certs	= 1
enable_strict_transport = 0
save_global_history	= 1
# color_visited_uris	= 0
# guess_search		= 1
enable_autoscroll	= 1
# session_autosave	= 1
history_autosave	= 1
autofocus_onload	= 1
single_instance	= 1
enable_socket		= 1
enable_js_autorun	= 1
auto_load_images	= 1
enable_localstorage	= 0
userstyle		= /usr/share/xombrero/style.css
# userstyle_global	= 1
# enable_favicon_entry	= 0
# enable_favicon_tabs	= 1
preload_strict_transport = 1
referer		= always
warn_cert_changes	= 1
enable_cache		= 1
js_auto_open_windows	= 1
# Search engines; uncomment one of these lines for you favorite search
# engine.
# Google
search_string		= https://www.google.com/search?q=%s
# External editor.
# NOTE: The editor specified here must not fork into the background.
# Examples of editors:
# external_editor	= gvim -f <file>
# external_editor	= xterm -geometry 177x58+0+0 -font -*-fixed-medium-r-*-*-15-*-*-*-*-*-iso8859-* -e vim -f <file>
# external_editor	= emacsclient -c <file>
external_editor	= geany -f <file>
# "default_script" points to a script executed by the run_script
# command. The only argument passed to this script is the current URI.
default_script	= ~/.xombrero/playflash.sh
# "user_agent" can be set to just about anything, for a comprehensive
# list see: http://www.useragentstring.com/pages/All/ . If more than one
# "user_agent" is given, then xombrero will use them in a round-robin
# fashion for each request.
user_agent		= Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US) AppleWebKit/532.0 (KHTML, like Gecko) Chrome/3.0.195.27 Safari/532.0
#user_agent		= Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7C144 Safari/528.16
## ALIASES
# Aliases are given in the following format:
#   alias = <alias>, <link>
# Where the link part might contain "%s", the "%s" will be substituted
# with the user's input when the alias is expanded.
alias = s,	  https://www.google.com/search?q=%s
# alias = w,	  https://secure.wikimedia.org/wikipedia/en/w/index.php?title=Special%3ASearch&search=%s
# alias = ports,  http://openports.se/search.php?so=%s
## COOKIE, JAVASCRIPT AND PLUGIN WHITE LISTS
# Add the domains you trust.
# cookie_wl		= .conformal.com
# cookie_wl		= .peereboom.us
js_wl			= .conformal.com
js_wl			= .peereboom.us
# pl_wl			= .conformal.com
# pl_wl			= .peereboom.us
## FORCE HTTPS FOR SITES
# Add the domains of sites that should be only accesed over HTTPS.
# force_https		= .conformal.com
## MIME TYPES
# PDF, note that xpdf can't load a URI directly; use "@" in front of
# mime_type to indicate to download the file first.
mime_type		= application/pdf,mupdf
# mime_type		= @application/pdf,xpdf
# Specific MIME type for video.
mime_type		= video/x-ms-wmv,mplayer
mime_type		= video/quicktime,mplayer
# Default MIME type for video.
mime_type		= video/*,mplayer
# Default MIME type for audio.
# mime_type		= audio/*,vlc
# Word documents.
# mime_type		= application/msword,soffice
mime_type		= application/msword,abiword
# Ignoring flash can be done by using the donothing pseudo-binary.
# mime_type		= application/x-shockwave-flash,donothing
## ADVANCED SETTINGS
resource_dir		= /usr/share/xombrero/
refresh_interval	= 10
url_regex		= ^[[:blank:]]*[^[:blank:]]*([[:alnum:]-]+\.)+[[:alnum:]-][^[:blank:]]*[[:blank:]]*$
gnutls_priority_string = NORMAL:%COMPAT
# NOTE: webkit 1.4.x overwrites these values!
# max_host_connections	= 5
# max_connections	= 25
## ADVANCED GUI SETTINGS
# The following low-level GUI settings are set by the high-level setting
# "gui_mode".
# The settings for "gui_mode = classic" are as follows:
fancy_bar		= 1
show_tabs		= 1
tab_style		= normal
# userstyle_global	= 0
show_url		= 1
# show_statusbar	= 0
# show_scrollbars	= 1
# The settings for "gui_mode = minimal" are as follows:
# fancy_bar		= 0
# show_tabs		= 1
# tab_style		= compact
# show_url		= 0
# show_statusbar	= 1
# show_scrollbars	= 0
# The following are settings shared between "classic" and "minimal"
# "gui_mode":
statusbar_elems	= BP
icon_size		= 2
cmd_font		= Terminus Regular 9
oops_font		= FontAwesome Regular 9
statusbar_font	= Liberation Mono 9
tabbar_font	    = Droid Serif Regular  9
## ADVANCED COOKIE AND JAVASCRIPT SETTINGS
# The following low-level settings are set by the high-level setting
# "browser_mode", and shouldn't be tweaked manually unless you know what
# you are doing.
# The settings for "browser_mode = normal" are as follows:
allow_volatile_cookies	= 0
#cookie_policy			= allow
cookies_enabled		= 1
enable_cookie_whitelist	= 0
read_only_cookies		= 0
# save_rejected_cookies		= 0
# session_timeout		= 3600
enable_scripts		= 1
# enable_js_whitelist		= 0
# enable_localstorage		= 1
enable_plugins		= 1
# enable_plugin_whitelist	= 0
allow_insecure_content	= 1
allow_insecure_scripts	= 1
# do_not_track			= 0
# and chop off "GDK_KEY_".
# Be aware that the names are case sensitive!
# The default keybindings are the following:
# keybinding	= command,colon
# keybinding	= search,slash
# keybinding	= searchb,question
# keybinding	= command_mode,!Escape
# keybinding	= insert_mode,i
# keybinding	= cookiejar,!M1-j
# keybinding	= downloadmgr,!M1-d
# keybinding	= history,!M1-h
# keybinding	= print,!C-p
# keybinding	= quitall,!C-q
# keybinding	= restart,!M1-q
# keybinding	= run_script,!M1-r
# keybinding	= js toggle,!C-j
# keybinding	= cookie toggle,!M1-c
# keybinding	= togglesrc,!C-s
# keybinding	= yankuri,y
# keybinding	= pasteuricur,p
# keybinding	= pasteurinew,P
# keybinding	= toplevel toggle,!F4
# keybinding	= help,!F1
# keybinding	= proxy toggle,!F2
# keybinding	= searchnext,n
# keybinding	= searchprevious,N
# keybinding	= focusaddress,!F6
# keybinding	= focussearch,!F7
# keybinding	= hinting,f
# keybinding	= hinting,period
# keybinding	= hinting_newtab,S-F
# keybinding	= hinting_newtab,comma
# keybinding	= userstyle,s
# keybinding	= userstyle_global,S
# keybinding	= goback,BackSpace
# keybinding	= goback,!M1-Left
# keybinding	= goforward,!S-BackSpace
# keybinding	= goforward,!M1-Right
# keybinding	= reload,!F5
# keybinding	= reload,!C-r
# keybinding	= reload,!C-l
# keybinding	= favorites,!M1-f
# keybinding	= scrolldown,j
# keybinding	= scrolldown,Down
# keybinding	= scrollup,k
# keybinding	= scrollup,Up
# keybinding	= scrollbottom,G
# keybinding	= scrollbottom,End
# keybinding	= scrolltop,Home
# keybinding	= scrollpagedown,space
# keybinding	= scrollpagedown,!C-f
# keybinding	= scrollpagedown,Page_Down
# keybinding	= scrollhalfdown,!C-d
# keybinding	= scrollpageup,Page_Up
# keybinding	= scrollpageup,!C-b
# keybinding	= scrollhalfup,!C-u
# keybinding	= scrollright,l
# keybinding	= scrollright,Right
# keybinding	= scrollfarright,dollar
# keybinding	= scrollleft,h
# keybinding	= scrollleft,Left
# keybinding	= scrollfarleft,0
# keybinding	= statustoggle,!C-n
# keybinding	= stop,!S-F5
# keybinding	= tabnew,!C-t
# keybinding	= tabclose,!C-w
# keybinding	= tabundoclose,U
# keybinding	= tabnext 1,!C-1
# keybinding	= tabnext 2,!C-2
# keybinding	= tabnext 3,!C-3
# keybinding	= tabnext 4,!C-4
# keybinding	= tabnext 5,!C-5
# keybinding	= tabnext 6,!C-6
# keybinding	= tabnext 7,!C-7
# keybinding	= tabnext 8,!C-8
# keybinding	= tabnext 9,!C-9
# keybinding	= tabfirst,!C-less
# keybinding	= tablast,!C-greater
# keybinding	= tabprevious,!C-Left
# keybinding	= tabnext,!C-Right
# keybinding	= focusout,!C-minus
# keybinding	= focusin,!C-equal
# keybinding	= focusin,!C-plus
# keybinding	= focusreset,!C-0
# keybinding	= editelement,!C-i
# keybinding	= passthrough,!C-z
# keybinding	= :open ,!F9
# keybinding	= :open <uri>,!F10
# keybinding	= :tabnew ,!F11
# keybinding	= :tabnew <uri>,!F12
Re: Xombrero,веб-браузер.
Спасибо, сейчас попробую :D
Вернуться в «Программы в Linux»
