vlc не определяет ТВ-тюнер GoTView USB2.0 DVD Deluxe
Настройка внешних устройств в Linux Mint Принтеры Сканеры и т.д.
celtic
Re: vlc не определяет ТВ-тюнер GoTView USB2.0 DVD Deluxe
Сообщение celtic »
у меня получилось, но сам не понял как, может мне объясните:
ivtv-tune -f 535.25; mplayer /dev/video1
Failed to open /dev/video0
MPlayer 1.2.1 (Debian), built with gcc-5.3.1 (C) 2000-2016 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /dev/video1.
libavformat version 56.40.101 (external)
Cannot seek backward in linear streams!
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
MPEG-PS file format detected.
VIDEO:  MPEG2  720x480  (aspect 2)  25.000 fps  8000.0 kbps (1000.0 kbyte/s)
Load subtitles in /dev/
Failed to open VDPAU backend libvdpau_va_gl.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 56.60.100 (external)
Selected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)
Opening audio decoder: [mpg123] MPEG 1.0/2.0/2.5 layers I, II, III
AUDIO: 48000 Hz, 2 ch, s16le, 224.0 kbit/14.58% (ratio: 28000->192000)
Selected audio codec: [mpg123] afm: mpg123 (MPEG 1.0/2.0/2.5 layers I, II, III)
AO: [pulse] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list,
e.g. -vf spp,scale instead of -vf spp.
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 720x480 => 720x480 Planar YV12
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO: [xv] 720x480 => 720x540 Planar YV12
A:   5.5 V:   5.0 A-V:  0.491 ct: -0.352 108/108  6%  1% 97.3% 65 0
           **** Your system is too SLOW to play this!  ****
Possible reasons, problems, workarounds:
- Most common: broken/buggy _audio_ driver
  - Try -ao sdl or use the OSS emulation of ALSA.
  - Experiment with different values for -autosync, 30 is a good start.
- Slow video output
  - Try a different -vo driver (-vo help for a list) or try -framedrop!
- Slow CPU
  - Don't try to play a big DVD/DivX on a slow CPU! Try some of the lavdopts,
    e.g. -vfm ffmpeg -lavdopts lowres=1:fast:skiploopfilter=all.
- Broken file
  - Try various combinations of -nobps -ni -forceidx -mc 0.
- Slow media (NFS/SMB mounts, DVD, VCD etc)
  - Try -cache 8192.
- Are you using -cache to play a non-interleaved AVI file?
  - Try -nocache.
Read DOCS/HTML/en/video.html for tuning/speedup tips.
If none of this helps you, read DOCS/HTML/en/bugreports.html.
A:  60.3 V:  60.3 A-V:  0.000 ct: -0.356 1490/1490  6%  0% 22.3% 190 0
отсюда http://avertv.ru/forum/index.php_showtopic=650.html я узнал про sudo apt-get install module-assistant ivtv-source ivtv-utils
но у меня появился video1, хотя у меня тюнер один и тот же.
здесь я нашёл http://www.beholder.ru/bb/viewtopic.php ... 9&start=45 как переключить на вход "по низкой частоте" через rca для видеомагнитофона,
Список возможных входов:
v4l2-ctl -d /dev/video0 -n
Текущий вход:
v4l2-ctl -d /dev/video0 -I
Соответственно указываем необходимый:
v4l2-ctl -d /dev/video0 --set-input=<num>
--set-freq= - это частота TV канала - это вам не нужно.
Все подробности тут.
v4l2-ctl --help
и с помощью ivtv-tune -f 535.25; mplayer /dev/video1 видео со звуком пошло, хотя там частота тв канала указана ?
celtic
Сообщение celtic »
вообщем получился хаотичный набор команд, но через vlc всё равно не хочет, и не знаю как выставлять параметры видео для оцифровки : битрейт и прочее параметры.
и ещё бы понять как сделать чтобы видео сохранялось в видеофайл ....
Каким образом собрали поддержку dvb в vlc в дистре неясно никому,логично предположить,что с xine подобных проблем быть не должно,либо брать исходники на git от vlc править кофигурацию и собирать.Когда использовал dvb проблем не было с плэйерами.Записывать ясно-дело,раз vlc не видит есть ffmpeg.
Ещё живо и это-наверно лучший выход
celtic
Сообщение celtic »
tupoll писал(а):Каким образом собрали поддержку dvb в vlc в дистре неясно никому,логично предположить,что с xine подобных проблем быть не должно,либо брать исходники на git от vlc править кофигурацию и собирать.Когда использовал dvb проблем не было с плэйерами.Записывать ясно-дело,раз vlc не видит есть ffmpeg.
у вас картинка во вложении - что я из неё должен понять, если вам не сложно объяснить, я ведь гуру в этих делах.
Самый понятный,простой гуй для dvb приёма у плэйера kaffeine,просто вспомнил его(объяснение картинки для гуру).Ну как я понял тут больше интересен сквозной видеоканал через карту,тут без скрипта самописного не обойтись явно,да получается "беспорядочный набор команд", у вас есть команда на включение видеовхода-появляется виртуальное устройство в /dev,теперь нужно считать в видеофайл с него -ffmpeg конвектирует как угодно и звук и видео,информации много про это https://ubuntuforums.org/showthread.php?t=2354678 man ffmpeg-можно почитать,хотя c vlc проще конечно,на первый взгляд.Не проще ли пробрести какой-нить китайский видеозахват с usb.Если научитесь включать видеовход на карте прям с плэйера не подсовывая ему патчи -научите тогда всех,благодарны будем.Мне лично интересно было б если бы вы проверили вот так:
ffplay /dev/video1
,если это работает то кроме ffmpeg в общем-то ничего не нужно для записи и контроля.
Последний раз редактировалось tupoll 04 май 2018, 07:51, всего редактировалось 1 раз.
Итак,если двигаться по регламенту нужно переключиться на видеовход с помощью v4l-utils -пробуйте
celtic
Сообщение celtic »
не правильно выразился - я как раз не гуру в этих делах
celtic
Сообщение celtic »
странно , когда установил ivtv-utis появился ещё и video1, теперь опять только video0 , video1 . не понятно.
попробовал - ivtv-tune -f 535.25; mplayer /dev/video0 - теперь только видео , а звука нет ....
ffplay /dev/video0
ffplay version 2.8.14-0ubuntu0.16.04.1 Copyright (c) 2003-2018 the FFmpeg developers
  built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.9) 20160609
  configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
  WARNING: library configuration mismatch
  avcodec     configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv --enable-version3 --disable-doc --disable-programs --disable-avdevice --disable-avfilter --disable-avformat --disable-avresample --disable-postproc --disable-swscale --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libvo_aacenc --enable-libvo_amrwbenc
  libavutil      54. 31.100 / 54. 31.100
  libavcodec     56. 60.100 / 56. 60.100
  libavformat    56. 40.101 / 56. 40.101
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 40.101 /  5. 40.101
  libavresample   2.  1.  0 /  2.  1.  0
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.101 /  1.  2.101
  libpostproc    53.  3.100 / 53.  3.100
[video4linux2,v4l2 @ 0x7f95b8009280] The device does not support the streaming I/O method.
/dev/video0: Function not implemented
celtic
Сообщение celtic »
v4l2-ctl --list-devices
Gotview USB 2.0 DVD Deluxe (usb-0000:00:14.0-4):
	/dev/video0
celtic
Сообщение celtic »
tupoll писал(а):Итак,если двигаться по регламенту нужно переключиться на видеовход с помощью v4l-utils -пробуйте
на видеовход получается переключится только так v4l2-ctl -d /dev/video0 --set-input=1 (http://www.beholder.ru/bb/viewtopic.php ... 9&start=45)
а помощью v4l-utils это как делать ?
или это так ? :
Вернуться в «Периферия»
